Almost toasted my electrical system...
I put cab lights on my truck last Weds. This morning driving to school (about 45 minutes, longest I've driven it since then) I started to smell an electrical burning smell. I just figured it was the cab lights where I wired them into the stock light switch on the dash (Green wire from the switch if that makes any difference). I was at a stoplight, next to my parking lot, so I pulled off my dash cover and quickly cut the wire going to the cab lights (wire cutters where still on the front seat luckily :crackup: ) The wire is 14 guage, so I pretty sure it's not that it's too small, it only came with an 18. The switch was very hot and the electrical tape was starting to melt. So my question is, how do I wire this so that it comes on with my parking lights without causing a possible fire! On OBS trucks is there a certain place to plug in to like there is on the NBS trucks? Just need some help! Thanks, Chris
Sounds like you have something wired wrong. If the kit came with 18Ga wire, then you should use it. I'm assuming that you used 14Ga in place of the supplied 18Ga and this adds resistance to the circuit (ckt). Wiring the lights through your current switch should not pose a problem depending on the load. (Not sure how much current (A) is being pulled from the lights) Double check the schematics provided and also check for any shorts to ground. Also, you may want to pull the schematics from GM on how the stock cab lights were wired.
It's been a while since my Physics classes, I didn't think a bigger gauge (14) would add resistance to the circuit? I've seen what can happen to a car when you use too small of a wire (+ wire going to amp from battery) :crackup: , never heard of harm by going larger. Checked all wiring of lights, they are all correct. Grounds are to the cab, positives are connected together, electrical shrink wrap around connections. Any other ideas? I may just buy another stock cargo light button and run a new circuit to it and wire it that way. Thanks, Chris
Add a relay. That way you have battery voltage running the lights. You should be able to use the same wire you are using now to trigger the relay with no problems.
Yes, this is your best option.
You need a SPDT relay (single pole double throw) the most common type.
the poles on the relay will be numbered.
Check this link:
Relay info
Hook a lead from your park light switch to 86 and a ground to 85
Run 12v+ (non switched) to 30
Use the lead from 87 to power your lights
You won't use 87a
You can get the 12v+ feed from one of the studs on the back of the underhood relay center. They have a fuse in the center to protect them (labeled Stud A or B)
Good luck
:crackup:
Would this one work? http://www.radioshack.com/product.asp?cata...ct%5Fid=275-241 I really appreciate all the help! Chris
Just to make sure I'm thinking correctly. The Green wire on the light switch I'm currently connected to for power to the lights are now going to be connected to pole 86. Get a ground wire and connect it to pole 85. Connect a 12v constant power from either stud A or B on the fuse block next to the PCM. Then connect the wire (14 gauge) that gives power to the lights connected to it. Are these numbers pretty much universal? Thanks again.
ONE more thing, is the reason it's getting too hot due to the fact I'm causing more power to be drawn than is provided by the output of the stock switch I'm using?
That link only goes to the front page.
The numbers on the relay are the same on all of the relays.
Yes, it is getting hot because there is more current being drawn through the switch than should be.
The coil on a relay has a very insignificant draw so that should take care of your problem.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 216 Guests (See full list)
