Low beams + High beams on '02 model??
Hey guys,
I started to follow the directions to have all 4 lights come on when I turn on my high beams, but when I started to install the diode, I noticed the 2002 wiring is completely different. Does anybody know how to do it? I have the appropiate tools and diode. :D
On the 2002 you don't need a doide just on the 2003 and up. here's the directions I followed.
1) Open hood
2) Remove brace from firewall to Driver's side fender.
3) remove top of Circuit panel
4) unhook the snaps from the passenger and drivers side of the cover...look hard they are there!
5) Roll entire circuit board over towards the passenger side.
6) Locate the Grey connector...there is only one.
7) at location D3 (3rd down 4th to the right) is a light gauge yellow wire. It is the only yellow wire in this row.
8) Tap this wire and ground it to the Light ground on the firewall. Follow the lead from the Hood mounted light, and you will find it ...just to the left (YOUR OTHER LEFT!!!) of the Master Cylinder.
9) Put your stuff back together...you are done...arent you glad you kept that cover?
Enjoy your new quad headlights!
I cut and pasted this from another forum but have done this and it works great. There is another way to do it using a relay but this is alot easier and since your working on the power side and not the ground you don't need a fuse. The lights themselves are fused on the power side of the circuit :D
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 649 Guests (See full list)
