1990 Sierra 1500 Speaker specs
TrAvIs 05
I just got a new CD player and it works great but the speakers SUCK. I need to get new ones but i need to know how many to get, what size(s), and where they are all located.
They ought to fit good. There are four speakers, two in the dash and two just at the corners of the seat in the plastic panel that goes up onto the headliner. That panel is a pain in the *ss to remove. You have to take out all the jack storage housing and then go after the screws because it's kind of shingled in there. And there are these annoying clips that you don't want to break.
You can do it, it's not so hard, but be VERY patient and have a few skinny flat screwdrivers around. There are more clips on that dang piece of plastic than you can count.
One thing, the benefits of better sound will be WELL worth it. Just take your time.
Don't do this:
:chevy:
Marko in Fernie, BC
pix soon!
....two  just at the corners of the seat in the plastic panel that goes up onto the headliner.  That panel is a pain in the *ss to remove.  You have to take out all the jack storage housing and then go after the screws because it's kind of shingled in there.  And there are these annoying clips that you don't want to break.
That kind of depends on the trim level. If it's a W/T or Cheyenne, then there could only be a couple of small grills covering the speaker holes. Those come off in about 8 seconds with no tools.
Xplods dont fit. I just went and bought some 4x6's at Walmart and the magnet is really big and it like sticks half an inch out of the dash hole. I'm getting the Pioneers today and if they fit in the dash then i'll go through and do the panel ones too.
Yeah, the xplods from the top of the speaker to the bottom of the magnet are bigger than the stock ones. The speaker hole in the dash aren't deep enough. Even with the little spacer that comes with it it still doesnt fit.
Also, i have to take off the seat belt to get those panels off don't i?
Yeah, if you have those panels, I'm pretty sure the belts have to come off.
You might want to look at plates. They sound a bit better if amplified, but they can do fine off just a head unit and give a bit more room for mounting.
If memory serves, there is more room on one end of the holes in the dash, and the bigger end of the plate can be swapped into the deeper part if need be.
I've used Boston Acoustics 4 x 6s as well as Infinity plates in the dash of my '92, which should be identical to yours.
The rear speaker holes should accomodate just about any speaker you want to put back there...Nothing but empty space behind there. Lots of room.
Ok, can i splice speaker wires or do i NEED adapter(s) and stuff? Here's pics:
The wires from the old speakers are light green and dark green and they don't have lines or anything on them so i don't know which ones positive or negative and the wires that came with the Pioneer speakers one set is white and one set is gray and one on each set has a line on it and the other doesn't. How do i know which ones connect to which because there aren't any instructions with them. The plastic thing don't fit onto the new speakers so is it possible for me to just cut and strip the old wires and splice them to the new ones and just clip the new ones onto the speaker?
Ok, so i spliced the front and they work now but i have no idea how to get to the back ones. I took out all the jack parts but i can't remove the bottom part of the storage thing i have no clue how to do it. Also, i don't think i have a tool to take off the seat belts either.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,259 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
