1500 + Trailblazer converter = OD lockup problems
A few locals have put torque converters from Trailblazers in their 1500s. Advantage is a modest increase in stall speed. Thunder Racing owner has 35,000 trouble free miles on his. I decided to try so he put a late model torque Trailblazer in my truck (5.3 X-cab GMC) along with a filter change and switched to redline tranny fluid. The converter locks at speeds anywhere from ~40 up to 55 results in a ~500 rpm drop. Since the change I've noticed that within 2 seconds of lockup rpms climb ~ 150. This starts a cycling of 150 rpm drop and rise on about 2 second intervals at speeds between 40 and 55 (worse at higher end) when at constant speed and on flat ground. Once over 55 the cycling goes away.
It has been suggested that the pulse width modulator valve (PWM) is worn but this only started after the converter and fluid change. At first I was thinking a converter problem but reasoning and learning of problems with leakage around the PWM valve has me believing the synthetic fluid may have brought out an already existing problem. I have 36,000 miles on this '03 truck.
AND I already have the TransGo shift kit with the PWM eliminator on my bench ready to go in as soon as I am sure that I have this anomally figured out.
In put from anyone that has any experience with this same swap and/or problem would be greatly appreciated.
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 411 Guests (See full list)
