Rough idle - changed many parts already
Hello everyone !
OK, here's my story:
I've got a 01 Tahoe with the 5.3L engine.
1. SES light came on - followed closely by some rough idle.
2. Diagnostics showed P1404 code.
3. Changed EGR valve (probably should have just cleaned it).
4. SES light went out - rough idle remained.
5. Took it to a shop to have them diagnose the problem. They said bad fuel pump.
6. I changed out the fuel pump myself (probably should have just started with
the filter).
7. Rough idle remains. :driving: Ugh!
I'm wondering what I need to do next. All suggestions are greatly appreciated! Please note: rough idle seems to occur mostly when in drive, stuck at a stop light (foot on the brake).
~ Signed, Disgruntled Tahoe owner
You could try running some good injector, changing spark plugs, plug wires, and possibly a new air filter.
Mine starts to idle rough when the IAC (Idle Air Control) gets dirty. The IAC is installed in the Throttle Body. along with the above suggestions, I would pull your throttle body and completely clean it with throttle body safe cleaner. Mine was filthy at 75K and it immediately smoothed out the idle. I clean it every 30-40K.
How many bolts/nuts or screws are used to mount the throttle body? I have a 2000 Suburban LT 5.3L and only was able to find one nut at the top of the throttle body to remove. I felt around under the throttle body for another one or two but couldn't find anything, and I could not get the throttle body to come off. What did I miss?
Thanks, Frank
Thanks, Frank
I believe there are three but it has been a while since I did it. When I get home, I'll check my Helms manual and post if the answer isn't posted.
Thanks, Frank
There is three. One at the top and two at the each lower corner. :confused:
Thanks, Chad. I look more closely this time.
Frank
Thanks for the advice! I'll try and get the throttle body cleaned in the next couple of days. I'll send another post if this fixes it.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 409 Guests (See full list)
