Changed My Own W/pump
my 2000 5.3 has been losing coolant for way to long so finally bit the bullet and bought w/pump and hoses, t-stat.
it came with the metal gaskets / w rubber embossed into them. took me 3 hours from start to final clean up of the mess by my self with only hand tools. i only needed a 10mm,15mm, 1 7/16 wench? for the fan nut, large chain wrench to hold the water pump pulley,and some pliers and screw drivers. the old gaskets had failed and the rubber part had come apart allowing coolant to run out of the seal, probably could have just changed gaskets but was already there so changed whole thing. used some rtv to hold gaskets to block as i attached new pump with bolts. the best part is there hasn't been any new leaks on my garage floor :confused:
hope this helps somebody else.
Good job man, I recently changed the pump on my friends 04 'Rado, and it took about the same lenght of time. It did give me an appreciation for having Electric fans on my 05 when it came time to take the fan off the 04.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 804 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
