Fuel Gage Again
the low fuel light is now coming on when i park the truck, but it's still running. as soon as i start driving the truck it goes off, i have 3/4 of a tank. is this a sign of things to come?
Eventually you will be replacing the fuel pump!
Ouch, thats gonna be a pretty penny.
If your good, goto a shop and pick up a old unit that has a burnt out pump...kinda tricky to get the pump line off but you'll be saving $500
I got mine from chevy for cost, $276, Installed it myself. I pulled the bed back instead of dropping the tank.
i did the sending unit way back under warranty, the thing's a piece of s**t. even after they did it,the gas needle still bounced around it would stay on half tank when i shut the truck off and as soon as i open the door, the needle would drop to empty. pile of crap. whats that gonna run me, $1k. as long as the pump doesn't go, i'll keep running it, i can figure out how much gas i have.
Try running a couple of tanks of Techron. It cleans the sulphur deposits off the sending unit which is usually the cause of the problem on GM trucks.
:D I had my rig in on friday for a dead fuel gauge, they had to order parts, so it might be a while before they come in :fume: , now I gotta keep the tank full. :)
+1 on the Techron. Get the full strength Techron and run it a 1 oz per gallon for 2 tanks. It is certainly worth the cost and many times it will correct the issue.
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 411 Guests (See full list)
