5.3 Oil In Intake
92Rustang
Hey guys I just did a new intake gasket install this weekend. When I went to clean the intake I noticed a liquid in the back of the intake. I turned it in every direction but could not get it out. It is oil and I think it is coming from the PCV, but is this normal? There seems to be a lot in there. Thanks
Yep. Normal. I did my intake gasket because I thought I had an intake leak. Turned out to be the water pump. Anyway, I wanted to clean my intake ports out because of all the crust built up and when I tilted the intake with the throttle body near the floor, about 2 to 3 oz. of oil drolled out. I did a little resarch and found out this is a problem with this style intake. Fortunately for us, the PCV hose is connected at the top and not near the throttle body like on some Vettes and F-bodies. There is a "catch can" mod they have been doing to keep the oil from getting into the intake. I cleaned the oil out of my intake with some brake cleaner and kept tilting it until very little came out. I figured it was 150k miles of oil but wasn't enough to worry about. Not sure how to get it out after it's been reinstalled though. Hope this helps.
150k on the truck & covered with years of oil. I'm sure the brake cleaner didn't hurt. The teflon coating was long gone by now. I was wondering myself what to clean it with, mainly the contact surface for the gasket, but couldn't find ANYTHING online about cleaning the internals of a plastic intake so I went with a oil solvent. If it was a new truck I might be concerned. Couldn't make things worse than what they already were. :banghead:
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,153 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
