Silverado - Blower Motor Runs After Engine Is Shut Off
stampeder
2000 Chevrolet Silverado 2500 4WD
Found the battery dead the other morning, discovered the blower fan had come on in the night when the truck was shut off.
Disconnected the blower at the resistor so I could have my truck back. Conventional wisdom on the boards says this problem could be caused by a faulty relay. I swapped out the Air Conditioning relay under the hood with no change.
Could this problem be caused by the Blower Motor Resistor? I have read in another thread on this board that resistors are a common problem, but they are usually associated with fan speed problems.
The truck and I are currently in Mexico for the winter, so I will likely have to import the part from the US, so I would like to be sure before I order any parts.
Thank you
Rob (from Calgary, currently in Puerto Morelos...near Cancun)
The blower motor resistor module has the blower relay built into it and it could stick as it does have power to it all the time from the FRT HVAC fuse.
Test to see if you have a faulty ignition switch, turn OFF the ignition switch and test for power at the HTR-A/C fuse which supplies the power to the HVAC controller's fan switch. If there's power, there's either a short to positive in that circuit, or the ignition switch is faulty.
If no power at that fuse w/ the keyswitch OFF, then there shouldn't be any power reaching the fan switch to power the blower resistor/relay in the low speed settings. Anyway, to test to see if power is coming from the HVAC controller's fan switch, test w/ the ignition switch in the OFF position and test for power (connect one test light or DMM lead to terminal, the other lead to ground) at these wires at the resistor/relay harness: yellow, tan, light blue, purple, & the correct orange wire. There will be two orange wires, one will ALWAYS have power straight from the FRT HVAC fuse, the other will be from the HVAC controller's fan switch and will only have power when the fan is set to high and the ignition keyswitch is turned to ON. If you want to find the correct one which comes from the HVAC controller, you can test the orange wire which has power, then pull that FRT HVAC fuse and see if it lost power, if so, then you know you have to test the other orange wire. If everything is testing ok, then you could probably assume the resistor/relay module is faulty. Good luck to you!
Here's a schematic, sorry if it's pretty crappy, cheap cellphone, lol. The upper right is the FRT HVAC fuse which is always hot, the upper left is the HTR-A/C fuse which is only hot w/ the keyswitch in RUN.
Hola Fortune50,
I did those tests and everything was exactly as you said. Looks like I have a faulty resistor/relay.
Many thanks!
Rob
Just a follow up here. I was able to obtain a new blower motor resistor/relay here at the GM dealer in Cancun, a miracle to say the least! The part number has changed again, it is now 89019089. They had exactly one in stock.
It looks quite a bit different, so hopefully it is a little hardier than the old design. In any case, it fit and it worked. Solved my problem completely. (Driving a truck on a highway in Mexico without moving air is not exactly fun)
My thanks to Fortune50 and this board for helping me out. This board is a precious resource!
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,331 Guests (See full list)
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
