Whats Wrong With The Rough Country 3" Lift
I know silverbullet2005 and Z71chev have both installed the kit, and then removed it. Maybe try shooting a PM to either of them. I'm pretty sure the problems with the kit are in the Rough Country ball joints.
I just installed this kit, the balljoints are what everyone complains about. . . and I had my problems with one.
But I called up RC and they were very helpful/willing to help me out, sent out a new balljoint. Its a very simple basic kit, thats why its so cheap, you could almost call it a bigger leveling kit-but the plus is that it comes with the upper control arms(upgraded option) to help offset some of the upper balljoint angle, the only downside I see with mine is that the tie-rods are angled a good bit.
THIS KIT IS JUNK!!! Period. The ball joints the sent me twice were garbage.. Nothing was machined right. The upper control arm bushing that came with the kit were toast in a very short time causing the whole upper a arm to move when you turn the wheel. I called them when I was installing the kit. The ball joints wouldnt fit between the slot in the upper control arms. they said hammer em' in they are tight. Meanwhile after looking at them they were completely different than the ones in the instructions. When they sent me the new balljoints and upper control arms (because I couldnt for the life of me get the old style ball joints out)......From some other company the zerk fittings were stripped out already and NO new bushings, so needless to say I was done with them. The leveling kit is great but this 3 in is a waste in my opinion.
and what (upgraded option) are you talking about .....the kit comes with the upper contol arms standard....at least they did when I bought it.
Ok so I just went to RC's web page.....They want you to CUT the bumpstop if you don't take the upper control arms....BUYER BEWARE....this kit is a joke guys seriously. Save your money for a quality lift.
Cut the f*cking bumpstop off? That sounds like a great way to over-extend your CVs and blow up your differential when they try to go back in, with the splines mis-aligned... :cheers:
I've heard if you buy the full $450 kit your much better off, as ppl have been screwing up their trucks installing the cheaper $200 one. Z71chev did you get the kit with the new upper arms or the cheaper one that req'd cutting?
Exactly....f'n idiots.... :D:D
Not anymore, UCA are the optional kit now.
They shouldn't even offer the kit without the arms. . .
No-where does is say cut it off, its more like trimming. . . the bumpstop is still intact.
By his post he had the UCA version. . . from what I've read on other opinions the problems could be caused with the 08+ and 4wd trucks.
I have a 07 2wd and hope everything works out, but only time will tell.
After a couple months with the kit on....I noticed a clunk in the front end when i'd turn the wheel while stationary. For the life of me I could'nt figure out where it was coming from but when I had my wife turn the wheel back and forth the whole damn a arm was moving in and out. The bushing was toast. Just to clarify if anyone was wondering. The kit WAS installed correctly and torqued to specs. Just junk materiels I guess.
Z71Chev, I understand you were burnt buy your experience. I can see were you would bash the kit as I have read in some of your other post.
But it seems that some folks are having great sucess with the full kit.
Maybe your kit was built on a Monday morning or a Friday evening. Even Chevy and GMC trucks have a run of bad actors
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 286 Guests (See full list)
