Need Help - Shutter/vibrations In Auto 4wd
My 2008 GMC Sierra 4x4 has an issue, it's got a 6" suspension lift and currently has the stock rims/tires on it for the winter. The truck has a bad vibration/shutter feeling while getting on the throttle and on the highway, the vibration/shutter goes away when switched to 2WD and comes back when in Auto 4WD. I took the truck to the dealer and they said they checked everything out and nothing seems wrong and said it's more than likely got something to do with the drive shafts being at severe inclines with the lift being installed. The dealer also drained the front differential to look for metal shavings and didn't find anything so they just refilled the differential. They recommended me talking to the lift manufacturer so I called them when I got home and they told me that a bad U-Joint on the front drive shaft would cause a vibration/shutter while in 4WD. This morning I removed the front driveshaft and checked the U-Joints by hand and they feel great with no flat spots or resistance issues. In my experience with bad U-Joints they've all had flat spots and siezed up feelings when testing them by hand. I'm going to put the front shaft back in and put the switch in 4WD High and see if it still has the vibration/shutter to make sure it does it in all 4WD options but for now I'm stumped.
Can the U-Joint be bad even though it doesn't feel like it's got a problem?
Any other suggestions for me?
Being a GM employee I have access to GM Service Information online so I did a quick check and found document ID 2193166 which states that if the vehicle is left in Auto 4WD, 4HI or 4LO for extended periods of time the Apply Plate and Bearing in the transfer case can result in failure. This makes sense since my truck was in Auto 4WD when I bought it brand new and has been in Auto 4WD basically ever since, I printed out the Service Document and dropped it off to the dealer so the Service Manager can look at it when he gets in. The first time I brought my truck into the dealer was for a grind/growl sound while driving and they replaced the right front wheel bearing which didn't fix the problem so this makes me think the grind/growl has developed into a grind/growl/vibration. Below is the Service Document I cut and pasted from GM Service Information.
#PIP4146B: Bearing Or Metallic Grinding Sound While Operating In Auto 4HI Or 4LO Modes - keywords grind growl noise - (Sep 16, 2008)
Subject: Bearing or Metallic Grinding Sound While Operating In Auto, 4HI or 4LO Modes
Models: 2009 Cadillac Escalade Two-Mode Hybrid
2007-2009 Chevrolet Avalanche, Silverado, Suburban, Tahoe, Tahoe Two-Mode Hybrid
2007 Chevrolet Silverado Classic
2007-2009 GMC Sierra, Sierra Denali, Yukon, Yukon Two-Mode Hybrid, Yukon XL, Yukon XL Denali
2007 GMC Sierra Classic
Equipped with Magna Transfer Case RPO NP1, NP8, NQF, NQH
This PI was superseded to add models and note. Please discard PIP4146A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment about a noise in the transfer case in either AUTO or 4WD. This may sound like a noisy bearing or a metallic grinding sound. It may also be accompanied by a C0327 DTC. The transfer case noise may be caused by an apply plate bearing failure. As pressure gets applied to the clutch pack the apply plate bearing gets loaded. Continuous operation in either AUTO or 4WD shortens the life of the bearing.
Note: Although there will be some characteristic noise while operating in 4wd, a NQF transfer case it is not equipped with a apply plate or apply plate bearing due to not having a internal clutch. If a noise is heard in a vehicle equipped with a NP1 or NQF transfer case see the operating guide lines below and compare to a like vehicle with similar mileage prior to attempting repairs.
Recommendation/Instructions:
The apply plate bearing designs in these transfer cases are not rated for continuous operation. They are intended for intermittent operation only when 4WD is required.
Long periods of continuous operation have been experienced in the U.S northern border states and in the provinces of Canada. This type of operation will shorten the life of the transfer case and in particular the apply plate bearing. As a general rule transfer case selector switches should be left in the 2HI mode unless road conditions dictate otherwise.
The following is a guideline for the proper use of 4WD in Magna transfer cases RPO's NP1, NP8, NQH and NQF.
2HI mode sends all of the drive train torque to the rear wheels. This provides the most fuel efficient driving mode.
Auto/4WD mode when engaged constantly monitors the vehicle's drivetrain to provide optimum traction as road conditions dictate. Torque is automatically transferred to the front wheels to provide seamless 4WD operation. Auto mode is intended for on-road driving that includes rain, snow, ice and gravel.
4HI provides enhanced traction for snow, ice, and gravel and most off road conditions. It is not intended for use on dry pavement.
4LO provides enhanced traction and increased torque multiplication to handle extreme on and off road conditions such as steep hills, deep sand, mud, snow and ice. 4LO can also be used during boat launch operations for increased torque availability.
Note: 2-4 Not intended for continuous operation.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 635 Guests (See full list)
