Service 4wd Light Cp327
dynodog62
I have a 2005 GMC Sierra 1500 and I have been having the service 4WD light come on. The first was probably a year ago, then ever couple of months for maybe a week at a time the service 4WD light would come on. So last week it start coming on again. Then one night after work the it showed on the panel the transfer case was in "neutral" pushed the 2H and I could hear it shift into 2H. The next day after work, showed it was in 4L, pushed the 2H and could hear it shift again. So, had an appointment at the local friendly gm dealer for new tires and had them check it out. And the write up description on the bill says.....
"test system, fault CP327 transfer performance fault, isolate fault to range sensor in transfer case actuator defer"
So they said they need to split the case to replace the sensor, $100 for parts and about $250 for labor (2.2 hours)....
Now about 2.5 years ago I had service 4WD light issues, and at that time it had a CO327, that was the encoder motor sensor shorted. Sensor was replaced in a short amount of time, I was just in for a oil change. Didn't have any problem with it til now....
In my research I haven't been unable to find anything about a CP327 fault
To my question......Is there indeed a CP327 fault or is a typo on the bill? If it is a typo and they meant CO327, is encoder motor sensor and range sensor the same thing? Or are they both generic faults that could lead to any number of sensors? Are they a bunch of idiots at the dealer?
I just don't know how GM's fault system works and don't want to get the run around from the dealer. I didn't even know there were any sensors inside the case. I haven't had it fixed yet, but I have an appointment on Friday....
Please Help and Ease my PAIN!!!!!!!
The letter "P" is adjacent to the letter "O" on every QWERTY keyboard, and that fact coupled with the symptoms you describe, combined with the fact that while there are P0xxx DTC's and C0xxx DTC's, there is no such thing as a CPxxx DTC, all leads me to believe that there is a typo on the work order estimate. I would assume that the intention was to type C0327, and you already know from experience what that means.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,259 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
