Oxygen Sensors - Where Are They?
oldtruckolderguy
My 2003 5.3L Silverado shows an error code that Bank 1 Sensor 1 heater circuit is bad. My electronic scanner shows that voltages from the sensors seem to be cycling OK but I want to replace the sensor with the bad heater so my check-engine light can be reset.
From other posts it appears that there are 4 O2 sensors but I can only find 2. Each of these is between the catalytic converter and the exhaust manifold. I unplugged the one I could reach easily on the drivers side and it has 2 black wires, a white wire, and a blue wire.
Where are the other two sensors? And most importantly exactly where is Bank 1 Sensor 1? I understand that Bank 1 is drivers side and Bank 2 is passenger side.
BTW, I know 2003 is not an old truck - but that is not my only one.
Thanks...
There should be 4 on the exhaust. Front and rear O2's.
Shoot...I'm not sure about 03 pickups. So nevermind. That's what's on my GTO.
Your knock sensors are under the intake manifold in the lifter valley...That's what I had to replace on my '02. Code was 0342 (03 something anyway ;D )
Bank 1 Sensor 1 is the one near the engine exhaust manifold on the drivers side, has a 4 wire connector that unhooks on the side of the tranny(I actually think the connector is along the fuel lines on a bracket against the tranny). Sensor 2 is right after the converter down(to the back) the pipe, and bank 2 is the other side in about the same places.
Yeah, that's what I was thinking. 4 on the exhaust (same as the Goat).
Yes, you are correct. I looked in more detail and found the back two sensors behind the catalytic converters just like you said. The wires were hidden from my view when looking from underneath the engine. I had to move back directly under the converters and then saw the oxygen sensors and wiring.
I will replace the front left sensor, using a borrowed tool from the parts store, and see if my Bank 1 Sensor 1 error code can be cleared.
Thanks again Wingnut and SuperTech64 for being here for me.
Good luck getting them off without them stripping.
If you've got the time, it's a really, REALLY good idea to shoot them with some penetrating stuff/anti-seize compound every couple of hours for a day before wrenching on them. My experience is that one out of 4 was put on cross-threaded and will come out like a mangled mess after you wrestle with it for an hour.
Of course...Since you're replacing them, you don't really care about it too much. I'm usually concerned with them stripping because we're installing headers and re-using the O2's....They're like $110 each for the GTO.
Good luck! :rollin:
+1 on the penetrating oil...it will change the whole experience.
Also, if you have a tap/die set, it wouldn't be a bad idea to chase the threads.
Good luck! :confused:
Taken out atleast a hundred(not that they go bad, but converters do and you have to transfer them over) in this type of truck and never stripped one myself... Penetrating oil is always a good idea though.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 1,242 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
