Need For Run/start Circuit Tap
Hi there,
I have installed a Sirius radio in my "01 Z71 and to power it I ran a wire direct from the positive connection in the red box (with a fuse). Since then I have added a Streamlight rechargable flashlight to the circuit. Both work great except for one small issue. If I forget to disconnect the flashlight from the onboard charging unit and the truck sits for more than 3 days the battery will be drained. The same happens with the Sirius. So the simple answer is to connect the power lead to a run/start circuit that works only when the key is on. I'm looking for the easiest avenue. The engine compartment power center doesn't seem to have any blank fused opening. The dash power center has none either. If one is available how do you tap it to run a power lead? Thanks
What I would probably suggest doing is to find a fuse on the interior panel that is switched to the ignition (acc/run), then run a tap line from that to a relay while also attaching your current power line to the relay. Then you'll have your good power source from the battery but it'll be switched via the relay so that it's on only when the truck is on. I can't remember which fuse to use, but someone may chime in or there could be info in the electronics forum.
    appletrav
    appletrav
  • Who's Online   0 Members, 1 Anonymous, 499 Guests (See full list)
