99 Gmc Sierrra Won't Go Into 4wd
llihkao
I have a 1999 gmc sierra 1500 5.3L extended cab pickup.
when i start the engine, the 2wd button lights up and stays on. the 2wd drive works great but when i push either the 4wd high or 4wd low button, the light on the button i pressed begins blinking and it blinks indefinetly until i press the 2wd button. the blinking light then goes out on the 4wd high or 4wd low button. when i then press the 2wd button the light stays on solid. also, when i have the 2wd button engaged and I press either the 4wd low or high button, i hear a "whirrr" type sound like something is moving underneath the truck. no messages appear on the dash. please help. thanks.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 1,009 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
