FS: Tonneau Cover
For Sale: Astro Euro-lid II tonneau cover for late-model, extended cab, sportside, S-Series P/U.
It has an aluminum mounting frame that clamps to the inside portion of the bed rail so it doesn't require any holes to be drilled. The cover lays on top of the bed rail so with the included weather-stripping it seals the bed nicely. It has a locking latch so you can secure your valuables in your bed. It's currently installed on my truck and to the person who purchases it, I'll let them watch me take it off so they can see how to reinstall it (if that's their preference).
This is a superior quality, heavy-duty tonneau cover and is in near perfect condition. It's been professionally painted to the factory 1999 Cherry Red Metallic. I've had it for 2 1/2 years. Here's a stock photo.
My picture links...
Pic 1
Pic 2
Pic 3
Pic 4
Pic 5
More information about the cover from the manufacturer's site is here...http://www.astro-cap.com
I don't want to hassle with shipping this thing so I'm only looking to sell to someone that can do a pickup/delivery in the DFW area.
Asking $500.00
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
