Converter Lockup Question
keckjr
I have a 1991 gmc sierra 1500 2wd 5.7L with an automatic overdrive transmission. I want to start off by saying that im not sure if this is an actual problem or just normal operation. This is the first of these models that I have owned and not sure what they are supposed to do. Everything im describing happens in O/D (4th). Anyways, the truck seems to be unlocking the converter when theirs no load on the motor. You can start up a hill and the converter will lock up and pull the hill with no problem, but once you top the hill and the load on the motor goes away the converter unlocks again and will stay unlocked unless you give it more pedal. If you give it more pedal after it locking up it will unlock again to give it more power to pull the hill just like normal. But it just seems like to much slipping. I live in the ozark mountains and this just seems like it would get so much better gas milage and less transmission wear if the converter stayed locked up at all times (in 4th gear) other then when your pulling a hill. No load=unlocked, mild load= locked, heavy load=unlocked (all in o/d). If you have any info it would definitely be helpful, even if its just to say stop worrying its supposed to do that.
My 4L60E did that for awhile and I found it annoying. I had a local shop install a "Super Servo" and that did the job. Simple and inexpensive to do.
Anon
Im pretty sure its not the servo, because it stays in overdrive at all times when its doing it. Thats why I think it may be something mechanical or electrical in the converter causing it to lock and unlock at incorrect times. I personally think its electrical because it shifts perfectly each time you pull out, but once you get up to speed and no longer are accellerating thats when the converter unlocks again. It maybe a bad sensor relaying incorrect info to the computer making it unlock at the wrong load. Dont these transmissions have sensors that tell the computer how much line pressure or load it has on it or is it a mechanical linkage. It does have a kickdown cable, but the converter has to know when to lock up the converter and that couldnt tell it. So basically im stuck in a rut until someone can give me some info on how the converter knows to lockup. Please any info would be greatly appreciated.
  • 4 weeks later...
First of all let me start by saying this is only an educated guess,because i have only owned one chev automatic.(I just recently bought a 2000 chev 4x4 auto.) Isn't the converter only supposed to lock under load? The reason is to save gas mileage. On my pickup I have a switch to lock up the converter. I was told to use this for towing on hilly terrain.I also was told that I would get less mileage with the converter locked up. If my guess is right the transmission will not go into overdrive with the converter locked, hence the lower fuel mileage.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
