My credit cards are gonna suffer
Already Done (in no particular order)
Dynomax Headers $225
Custom 2.5" dual exhuast $150
(2) Flowmaster 40 Mufflers $112
Roll Bar: $308
4 KC Daylighters $218
88-94 Steering wheel $20
Totally new wiring to & from starter & alternator
New Carburetor $230
Edelbrock 14x3" Low restriction air cleaner $40
Fixed interior light (changed fuse & doorjam switches)
Fixed wipers (added fuse/removed switch)
Tachometer $50
Tinted Windows @ 20%
Planning to/Need to do (in no particular order with *'s by the priority items)
* New steering bar bearing (pass side)
* 700R4 Tranny Swap $1400
* Change Valve Cover gasket on pass. side (part already purchased)
* Change pass. side Window Regulator (part already purchased)
* Adjust rear drum brakes
* Fix Horn
Wood Grain instrument bezel/vent bezel $170
New modern (88-94) column shifter lever
New dash cap $69
New door panels with wood grain inserts $170
Plush bucket-bench seat w/ fold down console in middle $600
Repaint metal trim inside
* H-pipe $30
* Tool box in bed $30 (small, weatherproof and tied to rollbar)
Cargo net $20
(2) Flowmaster 70's $200 (40's are too loud)
6" Lift Kit $400
36" tires $700
Step bars & grab handles
Fix Air Conditioner
* Fix Cruise Control
Detail & possibly paint underhood
New 6x9's & boxes for them $100
Wiring for towing
When I get all of that done, it will be one of the sweeetest old Chevy's I've ever seen or heard of.  My goal is to have it all completed and done by next summer, but we'll see.  Alot of it depends on if my car sells so I can get rid of that $330/month payment/insurance.
If you guys see anything that should be added to the list, by all means, please do :)
Thanks for readin'
-Mike
Hmmm...looks pretty comprehensive.  Should be a sweet(er) ride when you get all that stuff done...especially the lift and tires.
I'd post my list here, but most of it is little stuff for the Corvette right now, you all might get bored...
Jeff
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
