Instrument Panel "clatter / Rattle"?
So as the topic suggests, this is a bit of a wierd one...
Everytime I start the truck, I get a slight, quiet clatter from behind the instrument cluster - near the bottom - just above the steering column. It lasts only a second or son, and then fades. To go "old school", it sounds a bit like when the old speedo cables needed some lube.
It is also faintly (and I mean faintly) noticable when the truck is running, with the radio and fan turned down, but it's definitely louder when I first start it up.
So I assume this is not a serious issue, but just one of those things I'm curious about...
Any thoughts?
I have a 09 with less than 3k on it. Just got it back from dealer due to a similar problem. My problem was from a thin piece of stamped metal that is hot glued from the factory to something just under the steering wheel. Till I got it to the dealer I stuffed a piece of foam in that area 'cause I could feel the problem. The dealer used more hot melt to fix the trouble....yea I know.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 393 Guests (See full list)
