What Size Battery
hi all need a new battery on my 96 silverado 1500 350 ci as mine looses charge can anyone tell me what amp hour etc it should be as i cant find the details in manual
humore me i am in england cant just walk into dealer and get one
Per www.advanceauto.com ,
http://shop.advanceautoparts.com/webapp/wc...151_10051_-1___
You need 700 CCA ..
Group Size: 78
Voltage: 12V
Cold Cranking Amps (CCA) @ 0°F: 700
Cranking Amps @ 32°F: 875
Reserve Capacity (minutes): 120
Though it does specify that OE specs are 600 CCA
You need 700 CCA ..
Group Size: 78
Voltage: 12V
thanks
.. for these GM trucks, you need a Group 78 (that's the physical dimensions of the battery)
.. then buy the highest Cold Crank Amps (CCA) you can find in that size
.. try to find a 800 CCA... or more .... but at least a 700 CCA
I just bought a group 78 800CCA for my Suburban from Advance auto parts. Its the Autocraft Gold with a 3 year free replacement warranty for 90 bucks.
Hi. Try to look on the Internet just to give you the idea of the battery. But it's more advisable if you could go to the market. At least, you can see it personally before you buy it.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,255 Guests (See full list)
