Heated Mirror Not Working
I've noticed that my passenger side heated mirror is no longer working. I think it broke last winter but I was lazy and haven't fixed it yet. The Mirror still moves, etc, just no heat.
Does anyone have any trouble shooting tips or know the p/n that should be replaced.
Thanks,
Jansen
2004 Ext SLE Z71 5.3 with 68000 miles.
I'm betting you need the mirror glass,Seen many of them fail on the '03-'07 trucks,The part number for the RH side if you have the turn-signal mirrors is 88944392.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 1,009 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
