Help Fixing Door Rattles
I've got a 2001 Silverado Ext. Cab Z71 with the cd player up with the radio and a separate tape player down in the console.  When I listen to music on this completely stock system I get horrible door rattles that sound like they are mainly coming from the speaker grilles.  The bass on the deck isn't turned up hardly at all, but I still get rattles from bass.  The stock system sounds really good, but would sound 100 times better if it was rattle free.  How can I fix this?  Would Dynamat just around the speakers or on the entire door be worth it?  And would it stop the rattling?  I paid 30k for a truck and wasn't expecting it to rattle like 30 year old truck.  Thanks.
I have the same problem on my truck with new Kappas and Pioneer radio.
I only get a buzz when i have it turned up and am pretty confident that it will all go away with some Noise Supression panels (dynamat), and some thin rubber speaker gaskets.
Ill do it one day :D
Dynamat is a rip off, IMO.  Look into eDead by Elemental Designs.  I've used V.1 and just ordered some V.2.   the V.2 is just as thick as dynamat extreme and at a fraction of the price ($250 for about 36 sq ft of dynamat and $70 for 60 sq ft of eDead).
BTW, I sound dampened my doors and no more rattles.  I have a dedicated midbass in each door too.
I meant to put a link in here:   http://www.edesignaudio.com/ep/edead.htm
I'm actually gonna go with B-Quiet or Brown Bread.
http://b-quiet.com/test.pdf
BTW, Dynamat is $99 for 36 sq ft :D
I've used brownbread.  It's pretty good stuff.  Still a little expensive.
Where in the heck can you find dynamat extreme for $99?  Retail is $250.
i don't like any of the peel on stuff    I used rockford noise killer spray in mine and it got rid of any rattle that was lingering around
I suggest changing the stock speakers  especially up front  your missing out of some good quality from the paper  that they like to call speakers
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,304 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
