Z82, Whats Included?
Hello, I just bought a 1999 GMC 2500 CrewCab 4wd shortbox with the Z82 towing package. I have the factory printout using the VIN from the dealer and it clearly shows the Z82 package. However I think that somethings missing. It has a rear frame mounted tow hitch but no 7 way pollack connector. The wiring for the connector is tucked up above the spare tire. It came with the glovebox trailerbrake wiring harness to hook into the fusebox but there is no slot in the fusebox for it to fit into. In the instructions it says to add a 40 amp maxi-fuse to the underhood BEC in the stud #1 position. However when I look into this slot there is only a metal recepticle on the one side and not the other? Is this something that should of been done at the dealer when the truck was new? Or did the factory forget some key parts of my Z82 tow package?
This is what I have been following to install my brake controller, without much luck.
http://www.gmupfitter.com/publicat/bull/bull52.pdf
