Vacuum Leak
Guys, i'm a newbie, first post but don't seem to find an answer searching old threads. I have what sounds like a vacuum leak, most noticable at very light throttle. Brake peddle feels fine, hoses all intact and in place, and it's a 2004 sierra so no pcv valve to replace. Using old school technique with a paper towel roll, sounds like it is coming from the pcv tubing but it has no leaks in the tube(first bend down from intake connection). Any ideas would be great, thanks ahead of time. FYI just had fuel purge valve replaced, new int. steering shaft, new power steering pump, and am showing no live codes currently. Truck is running perfect, no loss of power. Very annoying sound can hear it over the radio, need help bad.
I've found the best way to find a vacuum leak is for you or a friend to light a cigarette and blow smoke around the area you think there's a leak. Use it all the time in the machinery rooms, works great. Good luck and welcome!
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 467 Guests (See full list)
