Autoride Suspension 2001 Suburban Lt
How can I test my system to see if it is functioning as I have no error messages or signs of life?
Is there a way to tell if the BCM or SCM are still working proper?
Also, what is the best way to convert an autoride system to a standard system?
Funny...I was going to ask the same question...my '06 Yukon Denali's Auto Ride has not came on in a while...and I get get it to turn on....
any idea's how to see if its working?
This may help:
I (finally) repaired my 2002 Yukon. I magine that your autoride system is identical to mine. Repair was quite simple, but costly!!! I had to change the whole Autoride unit and it costs 765$ Canadian (I live in Quebec) My dealer made me a deal, but still, I had to pay around 750$ Taxes included. The procedure for debugging and replacement is quite simple:
I located the level sensors. They are located near the rear wheels, under the little plastic fender lining toward the front part of the inside of the fender. It is just a little rod that is attached to the suspension on one end and to a rotary device on the other end. as the suspension moves up and down, the rod pushes on the rotary device. The rotation of the device will determine how loaded your vehicle is. This sensor will give the on / off command to the pump in the autoride unit. The upper part of the level sensor rod is tied to the suspension through a small ball joint. When you pull that ball joint firmly, the rod will come out, freeing the sensor. You can then manually rotate the sensor and make your autoride act like if the truck is under heavy load. When I did that, I could hear a very light noise coming from the autoride unit. When I was putting the sensor in normal position, this little noise was stopping. I did the same procedure on the passenger and driver's side and I could hear the same noise. This confirmed that my sensors were working fine and they were sending the "ON/OFF" commands to the Air ride unit. The whole air ride system is made of 3 different groups of devices: The sensors, the wiring harness and the autoride unit itself. I was quite sure that the sensors and wiring were OK. The only remaining item was the autoride unit itself. It sells as one assembly. it comprises a compressor, a pressure/dryer device and what I think is a solenoid. Only the pressure / dryer device can be purchased separately. The dryer sells for approx 350$ while the whole assembly (including the dryer) sells for aprx 765$. Since after 5 years, all the parts in the whole unit are about to die anyway, you might as well change the whole thing and avoid other problems. I'm a do-it-yourselfer, not a masochist, so I decided to change the whole unit. Changing it is easy. It is located behind the rear of the driver's side rear wheel. It is attached to the frame of the truck by 3 studs and nuts. These studs are inserted in the frame beam through 3 keyholes. All you have to do is to loosen the 3 nuts and slide the with the studs, out of the keyholes. You may need a little bit of hammering. Two of the nuts (the ones to the rear of the unit) are outside the frame beam, but the one that is toward the front, is located inside the frame beam. The genius who thought of doing that must have been smokin' good stuff! In any case, there is a hole on the other side of the frame beam that allows you to reach the nut with the ratchet (The spare tire is a bit in the way, but you can do the removal of the unit without having to lower the spare. Once this is done, all you have to do is remove the round 7 pin connector that connects the unit to the cable harness, unplug the high pressure tubing that goes to the shocks, and the intake tubing that comes from a small plastic box located inside the fender, near the refuelling hose. As they say in the haynes manuals: "installation is reverse of removal" :-) . The new unit comes with everything, including the little plastic box (probably an air filter) that is installed near the refuelling hose. This plastic box is tied to the vehicle through a special push pin. The pin also acts as a tube holding clamp. You know how hard these are to remove without breaking them. It may be a good idea to ask for an extra pin at your dealer. (Note to GM: at 765 bucks, you should include this push pin in the kit!) I did not ask for an extra pin... so I had to be very careful when removing the old one. I had to remove the whole fuel cap assembly to reach it. If I had had an extra pin, I would have just cut the old one and it would have saved me 30 minutes of my time.
Some other useful info: On the 7 pin round connector, the color code is:
Red and Black: Compressor + and -. My dealer confirmed that applying power to these wires will make the compressor run (if not broken of course)
Grey and blue: Going to what I think is the solenoid. The dealer told me not to apply any voltage to these wires, as it could damage the unit. I think the guy didn't know what he was talking about, but I did not take any chance anyway.
The other 3 wires (i don't remember the color) are going to the Dryer. I dont know how you can test this unit.
Part number for the whole Air Ride assembly: Delphi 15070878
P.S. My appologies if some of the instructions are not perfect. English is not my first language. Should you need more info, please do not hesitate to ask on this thread. I'll try to read it from time to time.
Stéphane
Source: http://www.tahoeforum.com/showthread.php?t=2795
I would try messing with that little sensor thing first....if not, it can get expensive quick.
This may help:
Stéphane
Thanks...
I tried to jump on the back of the denali but it did not come on.
I will try this...but i was putting alot of pressure on the back but nothing happened...so that is not a good sign.
Thanks...
hmmm, was it just you or was it with the boat/trailer?
Thanks...
it was me...
I have my boat in winter storage...i get it out next week...i will try it then...
but i was on the running boards as well..and was shaking the truck back and worth thinking it would come on...but it didn't.
Thanks...
it was me...
Trace the sensor that was mentioned above and fiddle with it...see if this works
Thanks...
it was me...
I will try...i'll follow up with I get a chance...thanks for the help guys.
I just did a bypass on my 03 Yukon Denali. Not sure if it is the exact same system but i would assume it is similar. This bypass's the "Service Ride Control" message i was getting because my compressor went out.
Just pull the sensors from the side of the shocks on each side (in the back)(can pull it off the top on the front) and put a set of 3.9 Ohm 25 Watt Resistors in there and it will read in the computer that everything is fine and dandy. You also have to pull the ride control fuse under the fuse box. The entire process takes about 3 minutes and then you can tape all that stuff up nice and tight with electrical tape.
I couldn't find the resistors in Radio Shack locally but apparently some electronic stores carry some of this stuff all the time, here is a link to the resistors i bought, i bypassed the back shocks for about $20, then put some regular Z71 shocks on there for about a bagfull of money less than a dealership would charge, or it would cost to just replace the compressor with rear air shocks.
Here is a link to the resistors I bought, these allowed me to not have to cut or splice anything, Good Luck
http://www.newark.com/jsp/search/productde...AFC-GB100000001
If you decide to keep the system functional. Arnott industries has good prices compared to the dealers. They also offer a set of Bilstein rear shocks for the Autoride trucks. It is still expensive but significantly cheaper then the dealer or even gmpartsdirect.
http://www.arnottindustries.com/
Here ya go, If you have any questions, let me know. :dunno:
http://www.fullsizechevy.com/showthread.ph...hlight=Autoride
http://www.gmfullsize.com/forum/showthread...hlight=Autoride
http://www.gm-trucks.com/forums/index.php?...ride+disconnect
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 802 Guests (See full list)
