Coil Spring Part Where Can I Get It?
Hi guys,
looking for the "lower coil spring insulator" as you see in the picture:
In the internet I just can find upper insulators
have you any ideas where to find it , as i am not in the US it must be via Internet, no dealer plz...
thanx malte
it is covering the lower part of the coil spring
as its better seen in this pic:
The lower one is not serviced/available anymore,Just the upper one is available.....
Subject: Front Suspension Coil Spring Noise (Install New Coil Spring Insulator)
Models: 1999-2004 Chevrolet Silverado 2WD 1500 Series
1999-2004 GMC Sierra 2WD 1500 Series Models
Condition:
Some owners may comment on front suspension noise. The noise may be described as a "bong" or "clunk" noise. The noise may be more noticeable when driving slowly over bumps or backing the vehicle out of a driveway.
Cause:
The front coil spring contacting the frame may cause this condition.
Correction:
A new front coil spring insulator has been developed to correct this condition. Install a new insulator to the top of both front coil springs. Refer to the Front Suspension subsection of the appropriate Silverado and Sierra Service Manual for coil spring removal/installation procedures.
This new insulator replaces any existing coil spring insulators. Remove and discard the existing insulator before installing the new insulator. Use the part number listed below.
Parts Information
Part Number - 15756770
Description - Insulator, Front Spring
Qty - 2
  • 3 years later...
Yes I know this is old but, it always comes up on a search so I thought I would help others, I found it once but cannot find it now. I have a 2000 Sierra 1500 4x2 on the bottom of the front coil spring ia a rubber insulator that kind of looks like a rubber spring. I know it has been replaced with a top mount but I have a leveling kit on top and I want an isolator for the bottom. What is the original part number for the lower coil spring insulator? Thanks
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 506 Guests (See full list)
