Rear Brake Light / 3rd Brake Light Problem
I have a 2003 Silverado 2500hd with a brake light problem. The third brake light does not work when the brakes are applied. But... if I manually push the lever on my electric brake box, the third brake light works but my two rear brake lights don't. I've disconnected the brake box from the relay center with the same results. The trailer brakes also do not work with the brake pedal, but will work when the manual lever is pressed. Is there a seperate circuit for the third brake lamp?
check the chismal fuse (center high brake light )
  • 1 month later...
I have the exact same problem with my 2002 and am looking on here to find out what the issue is. I really need to get this fixed asap as I am pulling my 28 footer to Houston next month from St. Louis. Where is the "chismal fuse" located?
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
