Rc 2" Kit Installed Today
2010 Sierra
-2" Rough Country Spacer
-275/65/18 Hankook Dynapro AT RFM Tires
-18x9 Moto Metal 957 Rims
Didn't really follow the instructions for the install, figured there had to be an easier way, and there was. Was done in about an hour.
All I did was:
-Remove bottom strut bolts
-Remove sway bar nut
-Use a bar to get the spacer in
-Line up holes and bolt together, easy as that.
Very happy with the results, makes the truck look a lot better IMO. Fell free to give your input.
any close up on wheels? I did same thing as u but i popped the upper ball joint loose. took me 40 mins with pulling and putting tires back on In a drive way
I can take some close ups this morning.
Here's a close-up of the wheels. Keep in mind this was before the RC kit was installed to see how much lift I needed to prevent rubbing.
  • 4 months later...
I don't have a side view photo currently because the stock wheels are on my truck for the summer. I'll get back to you in April on that haha, but in my opinion they don't stick out "bad". If you drew a straight line from the wheel well to the ground I would be surprised if they stick out an inch.
Looks good. Need to take that air deflector off the front under the bumper so it looks a little higher. Gives you alot more clearence as well.. that thing acts as a plow if you go through any water when offroading. Im installing mine tomorrow thanks for the tips. I'll put some pictures up when im through.
Leveling kit installed today.. pretty simple thanks for the tips. Here are some before and afters:
    Enduro73
    Enduro73
  • Who's Online   3 Members, 0 Anonymous, 1,566 Guests (See full list)
