Warm Startup Knocking?
jro909
I'm trying to figure out what is causeing this, if i drive the truck awhile..shut it down every once in awhile i will restart it and it will almost knock for about 20 seconds and be quiet..i was thinking maybe piston slap but on a warm engine!?
Hope you get some answers on this problem, my 2001 does the same thing, I can drive it to work and when I start it after sitting for the day in temps around 30deg celcius it will knock for a short time as well, drives me crazy but engine works get otherwise.
yeah the motor works fine, hell i don't even really get piston slap on cold start up. The motor itself is quiet besides the belts spinning, except for this warm knocking...i thought it could be that the oil is warmed up and thinned out and not hitting the lifters quick but then again the knocking isen't always there :)
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 792 Guests (See full list)
