Tac Not Working
ntimad8r3fan
I have a 1999 GMC C6500. The TAC does not work. I have asked several people and no one has helped yet. I bought a entire guage cluster from a parts yard, the tac still does not work. i have looked allllll over the bellhousing and do not see any sensor.
Does anyone have any suggestions or information on this problem. Thank you so much
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
