Cd Player Install
I'm getting a factory CD player for my 07 nbs truck, what do I need from the truck that I'm getting it from for the dealer to install it (I would call and ask but they are closed now and i'm buying it tonight)
My truck has just a radio, will the 6 disk cd player work?
I am guessing the harness in the truck would be the same no matter what radio you have. Should just plug in :D
Just a reprogram from the dealer. They will have to reset the theftlock and reprogram the cd player to correct the speaker output. I believe the 6 disks only came w/ the bose system. They will have to "teach" the radio what speaker package your truck has so it will increase the wattage to accomodate the lack of the bose external amp.
I replaced my 09 factory mp3 single cd with a 2010 6 disk radio with usb. Everything installed just like that was the radio the truck came with. Except for the reprogram.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 692 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
