2003 -275HP 4.2L I-6 Engine Changes
Has anyone seen a past thread on the internal changes to the 2003 4.2L I-6 Engine; with the HP being bumped slightly to 275 from 270 HP.  This thread provided in great detail some of the new internal for the 03 engine.  It would also be nice to know the starting VIN number of the 03 change over??? :eek:
Here are the list of 03 changes.  I'll post them on my site too.
tim
Vortec 4200 (LL8)
2003 Model Year Summary
· Polymer-Coated Pistons
· Oil Pump Refinements
· Cam-Chain Tensioner Improved
· Crankshaft Torsional Dampener Revised
· Head Gasket Refinements
· Spark Plug Design
· Calibration Changes to Improve Performance
FULL DESCRIPTIONS OF NEW OR CHANGED FEATURES
POLYMER-COATED PISTONS
Pistons in the Vortec 4200 (LL8) are now finished with a polymer coating. The polymer limits bore scuffing, or abrasion, of the cylinder wall over time from the piston’s up-down motion. The coating also dampens noise generated by the piston’s movement within the cylinder. The result for the customer is less engine wear, improved durability and quieter operation.
OIL PUMP REFINEMENTS
The oil pump has been revised to reduce operational noise. The pump has the same capacity as its predecessor, but its inlet and outlet ports--the passages where oil enters and leaves the pump--have been refined. The ports are now smoother, with no sharp edges. This design minimizes the hydraulic sound generated by many oil pumps and reduces overall engine noise.
CAM-CHAIN TENSIONER IMPROVED
The automatic cam-chain tensioner, one of the Vortec 4200's key maintenance reducing features, has been enhanced for even quieter operation.
The cam chain connects the camshafts with the crankshaft, and turns the cams as the crank rotates.  Even the most durable chains stretch with time, and in many engines must be adjusted or replaced at scheduled intervals. The hydraulically operated cam-chain tensioner keeps proper tension on the chain, even as it stretches with mileage, eliminating the need for adjustment and ensuring maximum efficiency over the life of the engine. Such devices are particularly challenging to develop for all-aluminum engines such as the 4.2L, because aluminum tends to expand and contract with hot-cold cycles more than conventional cast iron. As a result, the tensioner must be both flexible and extremely accurate to maintain perfect tension on the chain. After a thorough analysis of test and field data, engineers have developed more ratcheting range into the tensioner to precisely account for aluminum’s expand-contract cycles.  The previous tensioner design was adequate, but the new one further reduces cam-drive noise.
CRANKSHAFT TORSIONAL DAMPENER REVISED
The Vortec 4200's nodular cast iron crankshaft is now equipped with a single-frequency torsional dampener rather a dual-frequency dampener.
With the Vortec 4200’s long stroke, and the length of its crankshaft relative to the cranks in V-engines or inline fours, torsional vibration (in effect a wave of flexing from one end of the shaft to the other) can be significant.  At launch, this flex was addressed with a dual frequency harmonic dampener. Three steel discs, separated by two injection-molded rubber rings, were attached directly to the front of the crank, counteracting the inherent flex and virtually eliminating vibration. This solution was dictated partly by vehicle packaging. For 2003, platform changes have created space for a slightly larger crank vibration dampener with two discs separated by a single rubber ring.  Overall engine mass is not increased, and there is no obvious change to the customer. The new single-frequency dampener improves assembly efficiency and reduces piece cost.
HEAD GASKET REFINEMENTS
The 4.2L's cylinder head gasket is revised slightly to optimize coolant flow between the head and engine block. Further, the gasket manufacturing process also has been improved. The gasket is still made of embossed stainless steel and coated with a microscopic layer (.005 inch) of Vicon ceramic material. The coating is now silk screened and applied only around the cylinder bores and other critical wear areas of the gasket.
SPARK PLUG DESIGN
The Vortec 4200 is equipped with new spark plugs. The plug electrode has been changed slightly to enhance durability and efficiency.  A new welding process improves the durability of the platinum tip, ensuring optimal spark density and trouble free operation over the plug’s anticipated 100,000-mile life.
CALIBRATION CHANGES TO IMPROVE PERFORMANCE
GM Powertrain engineers have recalibrated the Powertrain Control Module (PCM) to improve fuel economy without a loss of power or engine response. The engine mounted PCM has one megabyte of memory and monitors 11 sensors on the engine alone, including crank and cam timing sensors, manifold absolute pressure sensor, oxygen sensors and oil-level and cooling sensors. It manages all engine and transmission functions and communicates via a digital data bus with a separate Vehicle Controls Module, which controls anti-lock brakes, gauges and other chassis functions. The cold-start idle speed has been reduced, and the PCM now has more  ``authority’’ to vary cam timing through the exhaust cam phaser.
The cam phaser has a hydraulically controlled helical spline and piston mechanism that changes exhaust-cam lobe timing relative to the cam-drive sprocket. Engine oil is directed by a solenoid to the appropriate passage in the phaser, turning the camshaft relative to the sprocket.  At idle, the exhaust cam is at the full advanced position for minimum intake-valve overlap.  That allows exceptionally smooth idling.  Under other engine operating conditions, the phaser adjusts timing to deliver optimal exhaust-valve timing for performance, drivability and fuel economy. The result is linear delivery of torque, with near-peak levels over a broad rpm range, and high specific output (maximum horsepower per liter of displacement) without sacrificing overall engine response, or driveability.
For 2003, the PCM allows the phaser to retard exhaust cam timing a maximum of 24 degrees (up from 20 degrees). This allows more valve overlap and slightly more internal exhaust gas recirculation. Together, the recalibrations are expected to increase EPA mileage ratings, accomplished entirely with careful software tuning and no additional hardware.
OVERVIEW
When it was introduced in the 2002 Chevrolet Trailblazer, GMC Envoy and Oldsmobile Bravada, the Vortec 4200 marked the return of an inline six-cylinder engine to Powertrain’s lineup for the first time since the mid-1980s.  While the industry at large had turned away from the line six, GM recognized that given careful design and development, the inherent advantages of inline six cylinder architecture were perfect for the new millennium. Yet with the technical sophistication of premium passenger car engines and the power of competitors’ V8s, the Vortec 4200 is no ordinary line six. Its flexible architecture builds the foundation for a range of inline engines, maximizing the return on corporate investment while exceeding customers’ performance expectations. Virtually every automotive media outlet has given the engine rave reviews, including being named to Ward's "Top 10 Engines" list.
most gratifying project that I’ve been involved in, to see the kind of reception it’s had. Motor Trend SUV of the Year, Ward’s Ten Best Engines award, chairman’s honors award—just a lot of real positive feedback. From this point on it’s continuous improvement, to keep making it the best engine in the world. That’s our goal.’’
Sorry, it is not possible to flash the PCM of an '02 with the '03... I have already checked.... I'm pretty sure that some of the boost in HP is from the "revised" areas of the engine such as the harmonic balancer, idler pulley, and some with the PCM, although supposedly that helps stabilize the MPG's in the lower RPM's like idle from what I read...
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 455 Guests (See full list)
