Oil Cooler Line Leaks Updated Tsb
for anyone having an ongoing problem with 2007-2010 gm trucks oil cooler line gasket leaks. there is an updated TSB on this issue dated 10/27/2010. obviously it is an ongoing issue because truck owners are returning w/multiple leak issues w/the oil cooler line gasket leaking even after cont. repairs. most issues sound like boneheaded mechanic repairs because the new issue is not taking the thin steel protective coating off of the gasket before putting cooler lines in place and NOT PROPERLY TORQUEING the two bolts in place. as well as the other usual issues. how do i know this? because this will be my fourth attempt on this issue. but this time the mgr. wants to replace my oil pan and install new oil cooler lines so he can rule out warpage... the mechanic doesnt buy the pourocity issue with bolts.i 90% think its a torque issue with my truck because the small leak starts at the center of the gasket. but i will go with him on this because he is tired of seeing me...lol the revised tsb # 08-06-02-003A. (notice "A" at end of #)
  • 1 month later...
Can you describe the details on the porosity issue with the bolts?
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 324 Guests (See full list)
