Do I Have Heated Mirrors ?
Hello,
I have a 2010 Silverado LT . It has rear defrost, remote start .... etc
Is there a package that the heated mirrors came in ? Also, where would the button be ? I heard it was the same as the rear defrost, but I can't tell if I have it or not..
Only reason I'm asking is cause I want to order towing mirrors and want to order the same features I have now ...
Thanks
You have heated mirrors,The rear defrost button turns them on/off.
There was no package they came in "per say",they are part of the LT trim level,If you look at your SPID label inside your glovebox you'll see the RPO code "DL8",this is the power-adjustable heated mirrors.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 544 Guests (See full list)
