Check Trailer Wiring Message
Ziggie
Hello,
Driving from work my 2008 GMC Sierra Votex MAX I was hammered with messges "Check Trailer Wiring".
I was not even pulling trailer since last fall.
I have factory brake controller, and fifth wheel connector in the box was spliced to the bumper trailer connector by the hitch installers before I even got the truck new, by the installers hired by the dealer.
Any idea what that message is indicating?, Should I pull the 40 A fuse for the trailer power?
Thanks.
Ziggie
how bout checking the wiring and making sure all the wires are connected and also check for corrosion
Yes, I will do that, I just checked, all seem to be ok on both connectors, and since I do not use trailer, it is possible that there is short being developed due to moisture. Will chek all tomorow.
So the problem is fixed.
The bumper mounted receptacle was full of water, on the back where the truck's trailer wiring wires plugs into that receptacle, seal must be bad or was not plugged all the way, there is rubber o-ring seal, yet it was full of water.
Winter is just ending here and it is very wet here.
I dried it up, filled with white nonconductive grease and plugged in, no warnings anymore.
It would appear that somehow the truck sensed the current leak, perhaps to the break controller and gave me the that message. I have the battery voltage there for charging the trailer battery if I use the trailer, so this must be the reason.
One more thing I noticed that when I was getting the "check trailer wireing massages", the alternator voltage went up, something like 15 volts or so. Normaly the voltage will be up for a while and then after the battery is charged to 100%, the voltage drops below 14 volts. This is called "Voltage Management' with is in new vehicles. When truck was new, I fricked out first time I saw the voltage gage go down at 200 km or so, I called the dealer and they explained this to me.
The question still remain, how the system knew there was a problem with the wiring.
I do not have schematics for this truck yet, it is too new and Hynes manual is not out yet, but I will try to get the schematics and figure out how the system knew that. Like I said, I think the brake controller sensed some votage on the "brake outpout" line and gave an alarm, due to low resitance in the receptacle from B+ to breake signal. No trailer was connceted for at least of half of a year. Preety smart if you ask me.
Ziggie
+1 the trailer control module monitors the connection. The water in the connector must have made contact across some of the wires making it think you had a trailer connected.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
