Going On A Road Trip
gregrocks89
So in august im going down to salmon arm bc for week and its probably time i should get some stuff done my truck. Just got to install my double din dvd deck, put new rotors and brake pads on, new wiper blades, new washer fluid line, wheel alignment, and a couple exhaust holes that have been slowly getting bigger to get patched.
Im bringing my dirt bike down and obviously its gonna be changed up like a mofo. Does anyone have any ideas on chaining their dirt bikes up? I was thinking since i have the box links welded on each side of the box, i was thinking on running a chain through the front tire to either side of the box, a chain thru the rear tire on either side and a chain going thru the front and rear rims. I have had a dirt bike stolen last year so im kinda anal about it now haha. Any ideas?
Salmon arm, cool, I was in that area a few years ago. Chaning anything down is the same process, as long as you dont put a strap through anything that moves with the suspension you are good.
I usually use ratchet straps on the handle bars, strap down. The back tire and sometimes the front depending on where im going
I usually put a chain through the rear rim, and the front rim, and lock them to the tie down points in the bed. I put some rubber hose over the chain to prevent it from chaffing on the rims.
Good idea on the rubber, i didnt think of that
i use brinks pad lock and put them through the rotors of my bikes when i need them locked up put one in the front and rear bike can only move a few inches unless lifted off the ground and carried
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 710 Guests (See full list)
