Grinding / Dragging Noise At Lower Speed From Passenger Front
Hey guys,
I went out of town on the weekend and left my 04 silverado parked at my parents house for the weekend. My dad told me it rained quite a bit while I was gone.
When I went to drive the truck to the gf's house for a few minutes, the truck was making a grinding sound (sounded like a brake caliper was dragging).
It would come and go and was not consistent and was not present at higher speeds (so I didn't think it was a wheel bearing).
I went in fwd direction and slammed on the brakes hard, and went in reverse and slammed on the brakes hard and it got rid of the sound for a little bit.
My dad came with me for a drive and it sounds like its coming from the passenger side front.
When on the highway I could not hear the sound. At lower speeds ( < 60kph) throughout the smaller towns the truck would make the sound.
Am I correct by starting by looking at the brakes? I'm worried because Id like to take the truck for a 500km trip on the weekend.
The sound comes in at lower speed, and goes away at higher speeds. I'd really like to get this fixed ASAP and any help would be greatly appreciated :lol:
I'd look a the brakes first... but check the wheel bearings too. The hub replacement isn't to expensive if you do it yourself. It's not a hard job.
Twice I got a small rock or piece of gravel stuck between a caliper and the rotor on my last truck. It made a horrible grinding sound, but it did it high speeds also so it probably doesn't have anything to do with your situation, but it can happen.
Is there an easy way to check the bearings? I know to jack the truck up, grab the wheel at 12 and 6 o clock and see if its got a wobble in it or take the tire off and give it a spin and see what happens. Is there any other way to know if the bearing is shot?
Got a friend who is a mechanic to look at it since I was pressed for time. Turns out the backing plate for the rotor was bent and was rubbing. He bent it back and its nice and quiet now :thumbs:
Thanks!
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
