New Guy Here
1freshsuburban
hey guys i have a 96 gmc suburban 6 lug 4x4 or k1500 5.7 vortec
i want to put new brakes on the truck and was woundering if there is anything out there factory that can upgrade my brakes like off a different truck or somthing that will give me a big rotor and bigger pads please let me know thaks guys
If your looking for better stopping power, I'd look at the powerslots and hawk ceramic pads. I've had good luck with them for towing purposes. Otherwise, you need to look at something like Baer brake kits with new calipers, and rotors.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 520 Guests (See full list)
