2003 1500hd Coolant Leak From Front Of Engine And P0300
tiacona80
I just took delivery of a used 2003 Chevy 1500 HD on Saturday. That night the low coolant light came on. The truck never got hot it runs pretty steady at 200-210 degrees. I topped off and the light went off. I;m noticing a slight coolant odor and a few drops of coolant dripping from the front of the engine that lands on the stabilizer bar and hits the ground. Can't really see exactly where it's from. Then today driving home the check engine light flashed on and off a few times and then went off. No performance issues or other messages on the display were noted at all. Checked for codes with my scanner and got a P0300 random misfire on all cylanders code. Any common issues you are aware of or ideas or suggestions.Wondering if the 2 issues are related or not. Thanks!
you're gonna have to use a light and look close ,up / down ,everywhere ....
water pump most likely (find the weep hole)...and missfire and coolant leak are not related
if private sale,you're screwed..
if a used dealer there SHOULD be a 30 day thing that SHOULD honor regards the leak and CEL
Thanks. I emailed the Chevy dealer I bought it from. I did buy it as is but I would think they would offer some help being that I brought it home 4 days ago. I am going to jack it up and make sure it's just the water pump. I will update with what the dealer said! It could be good or bad publicity for them on here!
shame on them for not having it inspected by a tech,
i used to love used inspections,all customer pay !!!! lol
Just replaced the water pump on my 05 1500HD. Found out that it was not the water pump, just the gaskets. Took a couple of hours, replaced the pump, gaskets and thermostat.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
