Hypertech Power Programmer 30019 2003 Gmc/chevy Gas Saver / Performanc
rcarmat
BRAND NEW IN BOX, Comes complete in box with all paperwork, including manual with step by step easy to follow instructions.
FEATURES
(depending on year, make and model)
Hypertech Power Tuning Tunes the engine for maximum power and performance, plus potential gas mileage improvements
Three-Stage Power Tuning Special Three-Stage Tuning for Select Vehicles. FOR 2003 GM TRUCKS, /SUV/ HUMMER H2. 4.3/4.8/5.3/6.0/8.1 LITER ENGINES
Dual Fuel Tuning Lets you choose optimized tuning for 87 octane or 93 octane fuel
Engine Rev Limiter Extends the engine's RPM range for a wider power band
Cooling Fan On/Off Temperatures Permits use of low-temperature thermostat for cooler, denser intake charge and lower engine operating temperature
Transmission Shift Points Optimizes shift points by speed and RPM for maximum acceleration
Transmission Shift Firmness Firmer full-throttle gear changes for faster acceleration
Top-Speed Limiter Allows the vehicle's top speed to be matched to the speed rating of factory-approved high-performance tires
Speedometer/Odometer Correction Automatically corrects speedometer and odometer readings for non-stock tire sizes and/or non-stock rear-end gear ratios (accurate odometer readings are required by law)
Read and Clear DTC's
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 425 Guests (See full list)
