Overhead Console
I've been casually looking for something to put in place of the blank plate of the overhead console in the trucks.  The Escalade/Denali DIC idea is nice but costs around $200.  So...I looked (again) at the Garmin GPS V Deluxe which can be had for under $500.  Two basic queries.  Does anyone own the Garmin GPS V? and How do you like it?  The second query is the windshields of the 99-0+ trucks....do they block RF signals by any significant db?
Tucson,
I have the Garmin GPS III+.  This is the predecessor to the V. It is the same physical size. I love it! I use it on my Harley as well as the truck. I have been thinking about mounting it in the panel as you describe. It may be a bit difficult to see driving down the road, but I may try it. The signal comes through the windshield just fine.
On the Garmin.
1) You will likely need to relocate the antenna when you put it in the console. The factory antenna uses a common “BNC” connector. It would be easy to make an extension coax cable out of readily available material. This will allow you to move the antenna against the glass and down from the roof line a couple of inches. There are external GPS antennas available, but I have not yet needed one. I was thinking about getting a On-Start antenna from a salvage yard.
2) The Garmin has a built in basic map that covers the highway and major streets of the US. You have to load the area where you are headed with the “detailed map”. This is done by connecting it to the serial port of your computer and loading it from the CD. I can load 6 to 14 counties on mine. The V’s have more memory, but the included map/cd (mine is mapsource, City Source w/Vs) contains much more detail. I think you can still only load the same amount of area due to the much larger file size. It would be nice to use the old mapsource data in the new V to get the greater coverage. Not sure if that is possible.
3) The PC interface is serial. It takes about 5 minutes for me to load a full mapset. The V will take much longer. I feel Garmin should have added a USB interface to the new V.
4) The V has a higher resolution in the same size screen. It can display a bit more info, but will be smaller.
5) I have played with a V but not had a chance to run it for any time. I wish I had the V, but the III fills my needs. It is not worth the extra money for me to upgrade. I feel the III+ and the V are the most versatile units out there. Depending on your goals, you might be happy with a III+ . I think it has been discontinued but I have seen a few available. The mapsource CD is extra. The Vs come with the City-Select CD. The V deluxe comes with all areas unlocked but the V basic only unlocks one area/region of the country.
There is a very good newsgroup on the net with great info. Do a keyword search on navigation or satellite and you should be able to find it.
Professor, thanks for the info.  For the antenna, I was thinking of using a BNC-BNC panel through connector mounted on the windshield side of the overhead console.  That the antenna is close to the windshield and is pratically hidden.
I've looked on eBay and the V is around $349 making the project a lot more do-able.
I'd be interested in seeing after install pictures. I'm hesitant to mount mine in the console because it spends as much time on the Harley! I’m going to have my console out to install home-link. I’m going to look at it closely to see what I can do then.
If you travel much, make sure you get the deluxe version with the unlock codes for all regions.
Check out the Garmin Street Pilot Color also. I thought about one of these in the lower console where the CD caddy is. A bit pricey however
OK Tucson, you’ve got me motivated.
I went and bought an extra filler panel to butcher today. I looked at the BNC-BNC idea. I don’t think it will work. I think it needs to be further forward to get a good lock on the GPS birds.  I’m going to chop the filler, make a jumper and do some testing. I it may be possible to locate the antenna on the mirror mount and catch enough satellites from all directions while still being semi-hidden.
I’ll let you know how it progresses.
I replied to this post on another board - but will go again with a little more info.
I installed the III+ in my overhead console.  You will not get any reception when installed there.  I went to the local Radio Shack and bought a 6-foot extension cable for $12.00 and relocated the original antanna just above the dashboard, I tried numerous locations and this was the best place for it.  The pictures below show the location of the antenna (red circles).  Sorry the pictures are so large, still trying to figure out this new technology.  With the antenna mounted here I can easily lock in on 10 different satelites alot quicker than before.  I have been thinking about a roof mount antenna just because of the visibility of what I have now but I cannot justify the price.  Tomorrow I will get some pictures of the GPS in the console and post.  I wired it into the map lights and it works fine.  I have found that with the tinted windows I have to have the backlight on to view it at all times.  When I want to take it out for the boat it is simply one screw removal for the console, two screws for the GPS and unplug.
  • 4 weeks later...
looking to do the same, Couldnt really see the pic of
overhead all that well, what I could see is what I am
looking for, how much did you end up spending? :jester:  :cheers:
    DaleB
    DaleB
  • Who's Online   5 Members, 0 Anonymous, 1,381 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
