pull the headrest up to full extended height. Look at the base of the headrest posts and you can see a small hole in the plastic trim piece. Put a paper clip or other small, stiff wire into the hole to release the headrest and pull! They come right off.
That little hole Mr. browne is refereeing to is located on the left inside of the right headrest post base base. It's on the right side on either the driver's or the passenger's side. On the left side base there is a button on the left, push the button in while pressing the paperclip or whatever into the hole and lift the headrest out. When I say left or right side, I mean you are facing toward the rear of the truck.
Lou
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,166 Guests (See full list)
