look at this pict
The silverado Im looking at is the black one (new body style, not the white old body style) if an old body style comes up re copy and paste the link and it should change
-KMT15
nope not that one, this is a 1500 EXT Cab.  ITs the one on the cover of the mag in the section where you can order different magazines
-KMT15
If its the truck with the small brush guard and the two hella lights mounted on the bar, and the pic is taken with the truck in front of some water, then I am almost positive its a Fabtech 6 inch. (although it looks shorter than 6, so its probably a 2wd) and the rims are Mickey Thompson Classic IIs with BF Goodrich All Terrains (probably 33's, 285/75s maybe).
I have that catalog in front of me.  No where in the catalog does it describe the mods to the black 1500 excab on the cover, but in the rear quarter window the truck has a "FabTech" sticker.  So the winner of the contest is jr.parrish  :eek:
Would I have to lift it to put those rims and tires on it?  How much do those rims cost?
-KMT15
Each rim would probably be about $185 and about the same for each tire. You would have to do some sort of lift in my opinion. I am running a near identical tire/rim combo (only difference is the rim. M/T II's vs Classics) and need my 2" body to make it work. If I had to do it again I would do a 3" body.
You maybe able to use ford keys and rear add-a-leafs to acheive the height without a body lift.
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 506 Guests (See full list)
