New door speakers 2004 sierra
yz2009
Ive got a 2004 gmc sierra extended cab. It has the stock 4 speakers without onstar.
The passenger side speaker died so its time to replace. Ive read that the stock speaker is 6.5" and there is also a tweeter. My question is for anyone whos had the door panel off, can i just replace the speaker with anything thats 6 1/4 or 6 1/2 and leave the stock tweeter in place? Also are there separate wires going to the stock speaker and stock tweeter?
Any input and speaker recommendation would be appreciated.
I run Polk DXi6500's in the front door and Polk DXi460p's in the rear. They sound great and weren't that expensive. I think I paid about $225 for the 2 sets at Best Buy. The rear 4x6's are components as well as the fronts. The rears have a 4" woofer with a tweeter next to it. The fronts are a 6.5" component with separate tweeter.
Here is the front. JB weld on there because I broke the factory tweeter mount
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Yes, you can replace one without the other. 6", 6 1/4", 6 1/2" are all basically the same. You wont have any issues mounting one verse the other.
Just make sure to get a 4 ohm speaker. Some companies these days are selling 2ohm speakers. They will sound better, but may cause the radio's amp to over heat and go bad.
If you like the low end sound of the factory speaker, then I would suggest buying a factory speaker, or similar. Aftermarket speakers will have better "highs" but will not have the "lows" since they will be seriously under powered.
I would go factory (or really cheap) if you are happy with the factory sound. The lower the power handling of the speaker, the better chance you'll get the lower frequencies (bass) out of them.
All depends on what you like.
Also, most major company's speakers will sound about the same since you are just using the factory radio. You wont really hear a difference.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 548 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
