Info on Rancho lifts!
I am about to get a lift hopefully and need some info, I DONT want anything over 4in for now!  I was thinking Rancho but then I heard that you cant really get just 4in out of it, that it will be closer to 6in!  Is that true?  Is it bad to run the TBs and CVs at Rancho specs?  I then thought about Trailmaster but have heard bad things about that kit, does anybody here know anything about the Trailmaster 4in?  Thanks for the info.
thanks,
Will
If I remember correctly, you can get almost 6 inches out of the Rancho kit if you set the T-bars at the factory setting, and it's closer to 4 if you use what Rancho suggests.  It may be the other way around, I don't have one so I don't remember for sure.
I don't know about the other lifts.
Rancho makes a nice lift kit though.   :thumb:
I keep hearing the Rancho is actually a 6in kit, and that its bad to run it at 4, is this true?  Has anybody ever actually run it at 4in?
thanks,
Will
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
