Removing front cv joint/axel 2008 GMC 4x4
How do you get strut out of the way to get axel to drop one more inch to clear differentical? I have everything loose but bump stop on upper control arm is hendering me ..Do i need spring compressors? Dont want anything flying out at me
Shock Absorber Module Bolt (Qty: 2)
Notice:
Do not use air powered tools in order to disassemble or
assemble any vehicle component. Bolt torques are vital to
diagnosis. You can detect bolt torques only when using hand tools.
Improper bolt torques can contribute to vehicle repair
problems.
Notice:
Refer to
Fastener Notice.
Procedure
  1. Support the lower control arm.
  2. Disconnect the electronic suspension control electrical
    connector.
Tighten
50 Y
(37 lb ft)
2
Shock Absorber Module Nut (Qty: 3)
Tighten
50 Y
(37 lb ft)
3
Procedure
  1. If removing the shock module to service its components, refer
    to
    Shock Absorber, Shock Absorber Component, or Spring Replacement.
  2. For the proper disposal procedure of the shock absorber,
    refer to
    Shock Absorber Disposal.
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 479 Guests (See full list)
