Zero oil pressure
Eightball
I have an 05 trailblazer with 5.3, In the morning when I start it I have no oil pressure and engine rattles, if I increase the RPM the oil pressure goes up and noise stops, if I let off the gas the pressure goes back to zero and it rattles, After it warms up a few minutes its normal and fine the rest of the day, I went to dealer and they told me to have the engine flushed which I did and that didn't help, Should I replace the pump or is there a different fix, It has 155.000 on it, Please I need some answers on this thing, Thanks guys
First thing you need to do is stop running it until you can get another gauge on it to verify it is the oil pressure and not just the gauge.
Thanks Chas0218. Its not the Gauge or the oil pressure switch, I had that changed, The engine rattles in the morning but after it warms up its fine the rest of the day, Its just in the morning when I have the problem, I am looking for some way to fix this problem without having to take the whole front end apart as its a 4x4, Its a huge job to replace the oil pump, Looking for suggestions.
are ya looking for a magical solution to a difficult job,,,,,,doesnt work that way ,,,,thou you can pay someone to do it for you ,,,,
not sure what else to tell ya brian,
oh and driving it will make the $$$$ go up
An answer like that wasn't really necessary was it?? All I was really asking is if maybe there might be something else wrong other than the oil pump, I can do the job myself, And no, Im not driving it, Its in my shop as im replacing the heads.
what else could it be ???? just sounded like you where being lazy thats all,you have service information to diagnose it further if your,,,a tech
so i said that ,,
i will gladly post a diag sheet for it if ya like brian
Im 55 years old and retired, No, Im far from lazy, Ive been there done that and came back for more, No, Im not a tech, But I can read and all I have is a repair manual, Ill get the job done, I just didn't want to pay a dealer 3 grand for doing it. Like I said, I was just asking a question as to weather or not it could be something else other than the oil pump, I already have all the parts, I just didn't know if I was missing something, I didn't think my original question was that misleading.
Everyone says dropping the pan is a huge hassle. All I see is disconnect the front drive line and axels (leave them in the hubs). Drop the axel drop the cross member and starter and the pan is easy pickins. Am I missing something?
O ring in the oil pump pick up tube has failed or deteriorated allowing air to be pulled into the tube, and oil has a difficult time getting pulled up the tube.. Usually only occurs on a cold start and then will be fine the rest of the day. After the pump picks up the oil, it will stop most of the air from entering the tube, but pressure may run a little lower than it normally does.
Thank you Lee for that answer, I will replace the o-ring, This Trailblazer has been everything except good, Its been one thing after another.'Again, Thank you
Supposed to be like a three hour job.. If you decide to replace the pump itself, which requires removal of fan, coolant, water pump, harmonic balancer, timing cover, oil pump, and oil pan.. It's more like five hours.
Im going to replace the pump, I have to drop the pan anyway to get to the pickup tube so might just as well do it all. Im going to replace the timing chain and gear as well. I should have just pulled the engine, Its all apart anyway, I had a blown head gasket so I got the heads done, The engine is still apart, This has turned into a diffacult job, But ill get it done, By Spring, lol.
Thanks Lee for your help.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,273 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
