Newbie first post
rervf23
I just picked up my new 2003 GMC Sierra EC SB Z71.
The dealer has installed the cheapest, ugliest looking
from license plate holder that I have ever seen.  It sticks
out farther on the bottom than the top.  Does anybody
know if there is a better license plate holder available
either from GM or aftermarket.  I have already installed a
Line-X spray-in liner. Looks real good.
Thanks,
Bob
YES, now that is exactly what I need.  I also like the license plate holder as well.  They are certainly nice trucks, but a little out of my price range.  I wonder if the SS plate holders are available for purchase by themselves?
Actually the owner of that SS turned his holder upside down and attached it to the screen below so that he didn't have to drill holes into his bumper cover see pic below.  But it looks very nice.  :thumb:
That is a very good installation job.  No holes in the bumper cover of the SS.
Maybe the one the dealer installed on my 2003 GMC is upside down. I'll have to check it out.  For some reason, it doesn't look right, slanted from top to bottom. I wish I could find one of those molded kind that appears to follow the contours of the bumper.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
