14 Chevy z71 HID projector swap
I've read threads until I'm cross eyed, and really don't have what I'm looking for yet. Is there an HID projector that will bolt right in place using the 4 bolts that hold in the OEM halogen projector? I understand I'll have to get an HID kit (planning on a DDM 55w 5000k), but I don't want to cut up my headlight to swap in new projectors. Any help is greatly appreciated!
http://www.gm-trucks.com/forums/topic/152762-hid-headlight-bulbs-hid-projector-retrofit/
Yes, the Morimoto FX-R. or you can use the oem infiniti FX projectors. Online reseller www.retrofitsource.com should be the only place you get from. Prices are reasonable compared to other places. but their customer service sets them apart. Been buying from them for 6 years now as I am retrofit addict
Link above shows how is done
Thanks for the info! I've been using DDM Tuning for several years on all of my previous vehicles, and like their service/products. I see that you mentioned the OEM Infinity FX projector....would this mean that the DDM Tuning IFX projector would work also?
I couldn't comment to using DDM projectors in there. From the sound of it they would be identical to the ones retrofit source uses. But I've heard of some bad quality issues with DDM projectors. And unless you have skill tuning projectors I wouldn't use them.
Also not much difference in price between oem FX projector and morimoto FX-R
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
