Running Jet-A in a diesel engine.
From what I understand, it will run just fine on the Jet A fuel. I've heard of a lot of people doing it, but of course when I worked for Cummins, I heard of a lot of pump failures because of it too. The Jet A doesn't have enough lubricity in it for the pump.  Basically the fuel lubricates the internals of the pump and without it, you will wear it out pretty quickly. I can't tell you about the specifics of a Duramax fuel pump, but I wouldn't want to chance it on my truck. Those pumps can be in the thousands of dollars to replace.
The Jet A doesnt have the wax or slightly higher sulfur content of #2 Diesel.  That and a bad thing is the EPA is kicking down the allowable sulfur content in diesel which helps to lube injection pump internals.  This is going to create some fuel related problems that resulted from the poor lubricating quality of low sulfur diesel fuel.  Since the maximum limit for sulfur in diesel fuel prior to around 1993 had been 0.50% or 5000 PPM, refinery processing not only lowered the sulfur content but also removed trace amounts of certain polar impurities.  Both organo-sulfur compounds and these polar impurities were the ingredients that gave diesel fuel its needed natural lubricating qualities.  The way high pressure injectors are now days, with all the multiplier pistons and such in them, the sulfur and whatever lubricants are really important.  The unit injectors and injector pumps wether it be a Zexel, Bosch, Denso or Delphi.  They AINT cheap, even if they are reman parts!!  Injector pump for a 2001 Cummins ISB (5.9) is $1430.00.  Manual equipped trucks take a different pump.  The pump for a GM 6.5 is like $850 bucks.  Im not sure about the new 6.6.  Id stick to #2 diesel.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 416 Guests (See full list)
